- Reaction score
- 157
CU job for a customer on a bit of a budget so little room for alterations.
Part of the job, I find a small single garage conversion to ground floor bedroom (ie a small room), converted in 1980’s. Found to have it's four sockets supplied via 1.5mm ring.
Anyhow, reconnecting into new CU, I measure a low insulation resistance on one jump of the ring. I have isolated that part, and converted remaining circuit into two radials, (IR measures up OK now), still using the existing 1.5mm, and fitted new CU with 10A MCB with label “10A Max”, and will also note it in EIC. Customer will never require much current in there since it's bedside lamps and a computer, and it's only the one little room.
Does a radial to sockets on 10A MCB in 1.5mm classify as “Departure form BS7871” as far as EIC is concerned? I can’t find anything which specifically says this can’t be done. I will be recording ref method A for the ex cables, hence 10A max.
