Discuss another contactor question sorry in the UK Electrical Forum area at ElectriciansForums.net
super
hi all thanks for any advice,i am looking into installing a contactor to switch multiple lighting circuits i cant find a design current supply needed to switch the contactor in any documents apart from mA ratings, the norm i always see is 6amps which is what i plan to use at the consumer unit to supply the contactor but why is it always taken as 6amps im sure looking at this contactor it requires mA but do we use 6amp mcbs as these are the smallest in general stock? are contactors designed to take a 6 amp supply to switch them over? im having to do a circuit design for the contactor and looking to start with the Ib rating and failed straight away,so only now asking the question after years of installing a 6amp mcb any knowledge very welcome thanks
A control circuit could be in place for a single switch to operate a single contactor, or multiple relays and switches and other input devices to operate multiple contactors.
The control MCB should be selected accordingly.
Most of the Industrial / commercial control circuits I've worked on generally have a 2 or 4 amp control MCB or fuse.
6A is usually the smallest MCB made by the various board manufacturers, so you choice is a bit limited. Personally I would fit a 2A fuse in your contactor panel for the control.
Reply to another contactor question sorry in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
