https://www.youtube.com/watch?v=wjitw3kED6w
It must be good, it's got "Flash Capacitor Tecnology"
Plus insulated staples;
HALEX-61400H | Acme Tools
Don't think I'd get anything from Acme. My mate reckons their gear is a load of rubbish. Then again his experience is limited to rocket packs, giant catapults, and magnetic roadrunner food.
Overhead - that's just not right. Agreed there should be one and someone may just know something we don't! Until then . . . Thumb in the G+T with more ice!
Sent from my iPhone using Tapatalk
You do and I've got one somewhere. Most are round staples for telecoms cables but you do get a few staple guns that take square staples for flat twin cable. I don't like using it because it very easy to put a staple into the cable if you're not really careful.I'm sure you can get specific staplers for flat twin cable. I'd never use one though.
Trouble is though, as you probably have experienced, is that unless the gun is bang in line and centred perfect over the cable, and you keep very still, its easy to nick or pierce the cable with a staple.You do and I've got one somewhere. Most are round staples for telecoms cables but you do get a few staple guns that take square staples for flat twin cable. I don't like using it because it very easy to put a staple into the cable if you're not really careful.
Yep, sounds like you have first hand experience of one. I think I only used it once about 20 years ago and on a run of about 10 meters I managed to scar or graze the outer sheath at least half a dozen times and penetrated it completely at least once. It was resigned to the bottom of a tool box and it's only been used once since by the mother in law to reupholster her dining room chairs. Maybe the newer versions are a bit more user friendly but I'd advise caution.
**edit** The one I have is a manual type with the spring loaded handle on top. Not sure if the 'Paslode' you mentioned in the OP is a more automatic type or not so maybe my warning won't apply.
