Discuss Basics of doorbell wiring (is there an L and N or 2 Ls?) in the DIY Electrical Advice area at ElectriciansForums.net
Few question, basics ones, does this diagram below show that (at the doorbell, the switch, not the chime) there is a live and switched live? As in, is the only neutral the power source to the chime (on the left?)
If so, is the idea of swapping this out for a digital/camera doorbell (e.g. ring, nest etc.) to make sure a live AND a neutral is taken instead of just the live?
What you need to find out is if the cable (2 core) from the bell push goes to a convenient location to mount the power supply that comes with the new doorbell.
But as it stands, the bell push has 2 lives, is that correct? Both of the cores going to it are live? But a modern day ring/nest doorbell must have a L and N instead, is that correct?
Thanks mate
it is difficult to know.
it is a power cable and a switch return.
if the transformer has one side of the secondary coil connected to ground then yes, it is probably a 6 or 12v Live and a Neutral connection.
if the transformer secondary coil is not connected to ground you have an isolated ac voltage and neither are live or neutral but there will be a voltage between them again probably 6 to 12v AC
if the transformer has a rectifier between the secondary winding and the output terminals, you have a DC voltage output. again this is probably in the 6 to 12v region but DC and the wires would be deemed 0v or -
and +12v or +
Reply to Basics of doorbell wiring (is there an L and N or 2 Ls?) in the DIY Electrical Advice area at ElectriciansForums.net
Amateur with no experience here - bought a Ring doorbell in the sale assuming I would just switch it out for my doorbell by removing and...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, So I ended up with a Ring video wired doorbell instead of a Byron video wired doorbell as B&Q were out of stock (had ordered online) and they...
Hi. I have a blink video doorbell and want to connect a 12v mechanical bell (pic attached below). I know Blink only allow 16v-24v AC transformers...
