Discuss Can I Just replace a 3phase motor with a single phase on my lathe? in the DIY Electrical Advice area at ElectriciansForums.net
I have a metal lathe, 1.5hp, 3phase, 575v motor. Can I just replace the motor with a single phase,220v motor? Would all the lathe wiring , switches, relays work? IF so, what HP motor should I buy? Thanks,
unlikely to be that simple i am afraid.
you will have to change the main motor contactor, overload relay, lighting transformer.
this is a minimum for a bog standard lathe, there may be other things that need adressing.
Reply to Can I Just replace a 3phase motor with a single phase on my lathe? in the DIY Electrical Advice area at ElectriciansForums.net
Hello Everyone -- So, I am looking to buy a used 5HP 3PH 208 V 10 inch Table saw --- (Motor Plate Data in Image) I am a DIY'er and in...
Hello right off the bat I'm a novice with a little better understanding than most(father was a electrician) but I am not an electrician. I'm...
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
