P
PAD66
I have been to look at a job today, they want a cat run wiring, It has two small panel heaters and a bulked head light. I am able to take a feed from a socket in the out building which has its own DB with RCD protection. My question is, is this classed as a special location therefore requiring an electrical installation certificate and notifying.
pad66
it needs certification, as does every job that is not a simple repair. not notifiable, IM0, but cables should have mechanical protection. cat's claws and teeth are sharp.
hang on. just going to milk the cat.
Puuuuuuurfect
when I read the title I thought the OP was planning to use Cat 5 or 6 for the sockets! lol
so....
have you made any mouse holes for this cat run?
- - - Updated - - -
if you put some cheese in there the cable might pull itself in as well....
Reactions: 2 people
Cat run wiring, certification
PAD66,
GLENNSPARK,
