- Aug 12, 2017
- 14,324
- 20,718
- 3,557,381
- 51
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
My eldest girl has a 10 plate Kia picanto. Bought for her by her grandparents, and she was supposed to be taking it away today, up to Aberdeen to move into her new flat.
During lockdown, it hasn’t been used all that much, but it has been used.
A few weeks ago, I swapped out the radio for a cheap Chinese thing with a screen, and Bluetooth.
Last week, I replaced both sidelight bulbs, and yesterday one of the rear wheels was jammed on by the handbrake.
Today. Two cars packed with all her stuff, first the doors wouldn’t open with central locking, then the ignition did absolutely nothing. Checked the battery.... 2.5 volts!
I don’t want to just charge it up, take it up to her and for it to drain again.
I was wondering if replacing the bulbs had caused a leak through to earth.(if there was already a problem with the switch? Can’t see it, as the lights are only powered through ignition)
I thought it might have been the radio? As it needs a perm 12v to keep the memory (I had to swap the 12v and aux 12v in the loom to get it to work properly) But that was fitted weeks ago, the problem would have appeared before now.
