Discuss colour changing 12v led's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
have a customer that has 2 colour changing led's controlled by one driver
now the customer had replaced the lamps becouse they stayed red but the new ones stay red to
where i come in i assume the driver is bu****ed but no whole saler can find the part no i had retreved from driver and the ownly thing that can suggest is a standard driver but i am thinking that the corect driver has a cicuit for changing frequancy to change colour am i right or will it work as i havent seen these before
I know that the ones I've found for boats (sorry, that's my standard reference :) ) need a pulse to change (momentary) then again to change through their controller. I use Mast 12v LEDs lights. Check out this link to Mast Products. Drivers, Dimmers & Voltage Regulators.
The Household D.Verdi products work off a dimmer...
"To change colours on either of the Deluce Verdi products you require a dimmer to be fitted to the circuit. This can be a normal 250W rated dimmer, or higher if required. At full brightness the halogen lamps are on full and the LED shows white light. If you then dim the lights down the halogen lamps go dim but the LED changes to a colour. To change the colour again you simply dim up and down again quickly." This was found here Verdi Colour Changing Mood Lighting | Recessed Downlights & Ceiling Spot Light
Good luck.
ITA
What is the driver? Is it a 1-10V? DMX? Proprietry with remote? aurora make nice LED drivers. Colour changers are often DMX512 as this offers the most control options.
Reply to colour changing 12v led's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
