Discuss conduit saddle question in the UK Electrical Forum area at ElectriciansForums.net
Hi, pulling a set in conduit is 90% bend, double set , over saddle etc, any form of shape you pull on the former is know as a set. H ave you done much conduit.?
Cheers, I've done a little bit, just starting using steel conduit not too long ago. Most of the runs were straight but have done a few bends (since I got a bending machine)
Apologies for not understanding but how does a relate to the way a besa box is mounted. Thanks
Looked at your earlier post, if using hospital saddles, just set to suit the besa box, so they are flush, no need to pack them out, you say you have a vice/bending let that do the work.
Oh ok got it now. Thanks.
If for some reason I wanted to pack them out what would I use (sorry for asking dumb questions lol)
Reply to conduit saddle question in the UK Electrical Forum area at ElectriciansForums.net
We are installing a new kitchen and the electrician has supplied the electricity under the base units, there is a spur for a socket that will be...
4K
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
I guess there are a thousand question like this, but I couldn't quite get if I can do this myself or need an electrician. I have a garage...
