Discuss Converting old circuit in the DIY Electrical Advice area at ElectriciansForums.net
Sharpy16
Hi I have a old supply (switch and fuse) that used to power an immersion heater it is fused by itself at the consumer board could this be converted into active sockets or would I need a new circuit fitted thanks anyone for a bit of help
High Sharpy16, welcome to the forum, I have approved you for the general forum for a quick reply although you may be given DIY status and the thread relocated when admin' is next on line, this won't effect any posts made.
Where are you based? I had an old mate called Sharpy among other things
generally it would be a 16A breaker (15A fuse) feeding the heater on 2.5mm cable. you can usefor socketrs, but retain the 16A. (always assuming that the circuit is sound).
i'm in stoke one day next week. can pop in have a look at it for you if you want.
Reply to Converting old circuit in the DIY Electrical Advice area at ElectriciansForums.net
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
I recently got my flat rewired. It had old storage heaters and we plan on putting modern storage heaters in. The way the electrician did the...
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
Hi, I’ve got a brand new dough mixer which won’t work. Out of the box it just popped when switched on and tripped the power in my shop. Using a...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
