Discuss digital multi meter recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Judd
hello, im looking at purchasing a digital multi meter for domestic testing purposes, I want the tester to be reliable, robust and easy to use, i have a fairly tight budget (£300-£500) and this will be the first mft I have purchased, i am willing to buy second hand. Im hoping in maybe a year or two splashing out abit more but for the time being i just need something! Can any recommend anything? and also ones to stay away from!
ive seen the fluke 1662 for £575 a little over what I would like to pay but it looks like it performs all the tests i need and comes with a few freebies and a years calibration.
thanks
judd
thanks
judd
Judd if you intend testing electrical installations, it's a Multi Function Tester, or MFT as they are known by Electricians, not a Multi Meter 2 different Animals Mate.
cheers, How many times have you called a ring final a ring main? i did acutally refer to it as a MFT later in the post. Im not here for pedantic trivia tbh so maybe stick to the forum guidelines and pipe down.
Not very often Judd, and I'm quite a pedant when it comes to calling an RFC a Ring Main as may members will contest to, can't imagine why you feel my post was pedantic, if you can't get the correct names for equipent you intend using, I was trying to help, seems you took Umbridge at what I offered as advice.
May be a change in the title in your post is in order,
Thanks Tel, I'll check them out.
[automerge]1592395347[/automerge]
Ok, sorry i flew off the handle.
you tink tay's bad.. just wait till they start tearing the arses off us poorsr scousers.
Well you tear the wheel off our cars..... turnabout is fair play ?. You're not the only one to get picked up on multimeter v MFT so I wouldn't worry about it, 2 very different beasts as has been said, although I'd love an MFT on the smaller size of a multimeter ?
Reply to digital multi meter recommendations in the Electrical Tools and Products area at ElectriciansForums.net
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hi, I'm buying a new test kit and was wondering if anyone had a problem with non trip earth loop readings? This was taken on the same...
I have an SWA cable running from the CU to the garden that the previous owners had fitted, but no longer worked when I moved in a few years ago...
4K
hey everyone, I am looking for some advice, I am thinking of getting a new DMM for industrial work, mostly motors, digital io, not much analog...
Hi all, Level 3 student here looking to purchase a GS38 complaint voltage indicator and could do with your recommendations please. I need a...
11K
