Discuss DNO Procedure for 7.5 kwp in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
S
Simonsaid
Hi
Can anyone point me in the right direction as to the procedure for a 7.5kwp PV system on a new school building?
Is it just a matter of contacting the local DNO?
If it's three phase you don't need to, its self cert through your MCS scheme. If it's single phase then Phone up and speak to someone at your local DNO.
Be polite and explain it's photovoltaic, using type tested inverters, and they "might" let you apply using the g83 form, or even self cert after.
Reply to DNO Procedure for 7.5 kwp in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all I had my PV/Battery setup installed in May and since then all my excess PV is just fed back to the grid for free. When I initially tried...
Hi, we are converting old farm buildings to commercial units, and as my father used to run a vacuum pump and compressor in his dairy I always...
Hi first time on this forum and looking for some advice. I have a second home with incoming network connection as shown below. I don't like...
Hi all, I was wondering if you could help me a sort out the problem. Is there any way (or device) to merge 2 three phase electrical supplies? We...
