Discuss engineer code for a sl compact panel in the Electrical Engineering Chat area at ElectriciansForums.net
whooooshh!! right over my head that mateyyou will need to crash it and reprog it if you dont know the codes
not really as you will still have to reprog the new one,crashing(defaulting it) would give you same as a new one..
does it sound outside when you kill the power.
would that cause the panel to go into alarm when juiced up though?if it beeps rather than rings like it should,id say sounder battery is faulty,it should sound like it would if the alarm activates,probably need a new sounder
Reply to engineer code for a sl compact panel in the Electrical Engineering Chat area at ElectriciansForums.net
