Discuss Exploding socket in the UK Electrical Forum area at ElectriciansForums.net
G
Guest111
Went down to help a friend today put some sockets in his office,small ring main with 8 twins on it.All wired in and do all the dead tests IR R1 R2 Polarity etc,power it up and plug in to do a Zs try one socket,good reading move on to another again good reading move on to the third,plug in switch socket on and BANG!big blue flash and mate leaps backwards I,m stood there slightly stunned mate asks wether it should do that( lol)after a bit of cursing I check breaker is off and carry out safe isolation tests(oh yes I,m out to impress on this one) remove socket and retest,all ok turns out there is a fault on the actual socket so thats going back on Monday.It was a G E T twin socket from neweys sold under their Newlec brand,first problem I,ve had with newlec but there you go so look out people just in case its a batch.
GET sockets are notorious for such problems. Usually this is caused by the rear plastic moulding cracking or the moulding fixing screws over-torqued at the factory. When a plug is inserted the rear moulding distorts or springs apart, releasing the switch gear to short the busbars.
MK arnt what they used to be !
Overrated and overpriced, and terminating them is awful, especially cpcs
We use crabtree and click polar stuff, admittidly the polar stuff is cheap, we have never had a problem with it
I wouldn't say just over 3 quid is overpriced tbh. At least they are reliable and the terminals line up. My only issue with them is that the screws are a little soft and can get chewed up if care isn't taken when tightening.
Love crabtree stuff too but found click polar a bit hit-and-miss.
I find crabtree and volex are good, volex being the same mechanicals as crabtree just a bit naffer looking.
mk white placcy is pretty poor now, however I still use there metalclad and masterseal are the best.
I've come across 2 types of white, plastic GET double sockets. The more solid one has the terminals adjacent, in a row (from Elec Centre). The other (from Neweys), which I would think is the one in question, the terms are strangely positioned. Both look exactly the same facially. Is one a later, improved version? GET are now Schneider, normally top stuff. The GET 'ultimate' range is class, but very expensive, even more so once Schneider got involved. The price rocketed a couple of years ago.
I got a load of Crabtree sockets, they had a good finish and are a nice fit. But I think the terminal screws let them down, have to really push hard otherwise I find the screwdriver slips, fails to tighten and results in loose connections. MK are expensive, and cheap doesn't have to be poor quality, deta are good (for the price) so is contactum. Don't shop in neweys if I can help it as they don't operate chip and pin
Chances are, one is double pole the other single pole, the crabtree difference between double and single pole ones are just like what you describe.
MK masterseal are good in a way , but a pain in the arse trying to open and shut them
We have been using BG outdoor sockets, really good in my opinion and doesnt cost the earth, i paid ÂŁ12 for a double not so long back
I keep hoping someone brings out a decent pre wire-able back or surface box, so that you can just push the socket front in like a Sangamo time clock, and two screws job done..In my dreams
J
Yea I use them at work ÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁÂŁ... but a very robust construction, I always like to fit them with the full enclosure they sell, makes for a nice tidy job
J
Agree about the BG outdoor. Very good quality and robust for the money.
Reply to Exploding socket in the UK Electrical Forum area at ElectriciansForums.net
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
So a regular client has just had me finish doing up their flat and bought a house, been and while quoting for LED downlight etc.. they asked to...
Visited my mates place tonight as moved to a new property 2 yrs ago, starts going through the rooms, and wisely leaves the elec alone ! Find a...
Hi all, I am undertaking a partial rewire of a house that a client is needing to do quite a bit of surgery on as tenant just left and what a mess...
My mrs recently new bezzy girl mates partner has some property, my mrs said, " my hubby do it for ya at a good rate " joy i think. I had this...
8K
specs
S
