Discuss Failed EPC in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Does anyone know what happens when panels are installed on roof and the house fails its EPC. Would I have to remove them, not got anything in writing regarding this issue.:hanged:
you work with the EPC assessor to find the lowest cost way to get it to a D.
If there's no way of getting it there, then you're probably a bit scoobied if you've not got this well covered in your T&Cs. Either removal or a partial refund proportional to the percentage reduction in payback would probably be worst case scenario.
This probably is best discussed in the sun lounge though - are you able to request membership for that?
My assessor likes to them after we have finished to push the figures up. The place in question has double glazing, loft insulation, cavity wall, thermostat controls, a few low energy lights and a dreaded LPG back boiler. That caught me out. He wants ASHP next year. He can not afford it this year.
Unsure how to request the sun lounge
detached?
what points did it get?
all energy saving lights
cylinder jacket on hot water tank
Immersun for water heating? Should be able to persuade the EPC assessor to put that down as solar water heating IMO
that'd get you a few points if you're just under.
We get these all the time - I've turned away 3 jobs in the last month for similar reasons. If I were the customer I just wouldn't apply for the Fit for a year until I'd sorted out the heating side of things. Prices will have increased by next year so he's saved some cash on his install by doing it this year (potentialy enough to ofset not getting the fit this year and got some free electric. Next year he'll get a slightly reduced fit payment. Even at 7.1p it's not the end of the world, the return is still often better than ISA's it's just that the expectation is for 15.4p.
Something seems wrong with that score to me. Why don't you have another EPC done with a different assessor and re-lodge. With what you have said about the property along with the PV surely it would be a D.
"Earthstore, why do you jump in with both feet before knowing all the facts."
Sorry Jason. do you remember that quote??
At least mine was only advice, but installing PV without the EPC facts, come on, really..
I feel that your assessor has cocked up somewhere though, and I truly hope that you can sort it.
We actually get the EPC afterwards but only on houses we know will already have an EPC of D such as houses built in the last 30 years with most boxes ticked. The older properties with solid walls we will get a predictive EPC done as if the solar has been installed that why we can install with confidence knowing the property will have an EPC of at least D.
We always get it done before, unless the homeowner already has an EPC. The assessor doesn't lodge the case if it has not met a D, if PV will push it into the D bracket, he revisits after the installation to fulfill his requirements for his accrediting body and then lodges. It costs a little more but I prefer to know 100%.
I hope you get it sorted.
We get these all the time - regardless of the person doing the EPC. Back boilers are around 60% efficient, even natural gas ones struggle to get a decent rating unless there's substantial insulation & double glazing. Add lpg and you're doomed. It's rural discrimination clear and simple - if you have access to natural gas then you have to spend a lot less than on getting an EPC of D than if you're off the natural gas grid. Infuriating!
We had an F rating last week for a 1991 property with full cavity wall and loft insulation, zoned heating and double glazing. The reason - wet electric heating. It was going to cost the best part of 4-5k to put new oil central heating in and his bills would have been higher because his electric heating runs off peak 5.4p/kwh instead of 6.7p/kwh for oil. He'd have achieved a D rating with it though and could have had his pv at 15.4p. We did the decent thing - told the truth and lost a sale :(
I leave it for the assessor to book in the appointments. I send him the information and install dates and he decides when to turn up. He is young and its his first LPG system on a back boiler. Live and learn the hard way. Told him to do the EPC before the installs last night :6:
Reply to Failed EPC in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
I am upgrading garage lighting. I have installed 12 40W batten lights (cheap Amazon variety - don’t have specs). 6A breaker in Garage consumer...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Hello I have recently moved home and I looking to upgrade lighting across the house to LED. In the kitchen I have found that there is installed...
