O
Old Jag Lover
For a good laugh,go to Renovate forums,just google it,drill down to electrical find crap electrical,400amp fuses blowing well lets replace them with slabs of aluminum,it's all there.
Had a guy in Sydney do stuff like that when he worked for me everything from smashing a granite slab to install an earth stake never seemed to occur to him that with a 3 inch copper water pipe buried in concrete 6inches thick,200fot long,thus forming a ufer ground,no earth stake was required,nor did he bypass the plastic water meter with a bit of 25mm earth wire,to wiring a 2 way switch using the carter method,light was always live, to twist cables together on a service drop without using Polaris taps or split bolts,plus he smoked weed,so he had to go.
You're not posting using predictive text by any chance? As all your posts seem to confuse!Had a guy in Sydney do stuff like that when he worked for me everything from smashing a granite slab to install an earth stake never seemed to occur to him that with a 3 inch copper water pipe buried in concrete 6inches thick,200fot long,thus forming a ufer ground,no earth stake was required,nor did he bypass the plastic water meter with a bit of 25mm earth wire,to wiring a 2 way switch using the carter method,light was always live, to twist cables together on a service drop without using Polaris taps or split bolts,plus he smoked weed,so he had to go.
