Discuss Help to identify this wall switch in the DIY Electrical Advice area at ElectriciansForums.net
everest63
Hi!
The house was built in 1978. There is a wall switch of a style and function I cannot identify. The switch is like a rocker switch but it goes in both directions and springs back to level again. One is in a bathroom and the other in a den.
Dimmer? Blinds? Roller shutters?
I assume you've tried pressing it?
Think the OP has gone. Maybe he pressed it and something bad happened :D :)
Hi!
Everest are you having problems or do you want information on the switches
Reply to Help to identify this wall switch in the DIY Electrical Advice area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi. I am trying to replace a heating timer with a smart switch. The current timer is the type with a dial on the front and 1 to 24 written on it...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hi New to this forum, Just looking for some advise as a DIY person. I have recently purchased a new home. I have come across a wall light which...
