Discuss help with a fan speed controller in the UK Electrical Forum area at ElectriciansForums.net
aleen
Hi guys
I'v got a question to do with a fan speed controller. it is Ziehl Abegg 560 mm, single phase. use electronic speed controller 6 amps..just replace a new same fan motor, when lower speed, controller temperture go up 30mins fuse(10amps)blow. when high speed , controller normal.. any advice?
Thanks in advance
Do you have Frequency inverters? Frequency inverters are ideal for use in the energy efficient control of all types of motors. ZIEHL-ABEGG supplies frequency inverters that are perfectly matched to customers' applications.
hi there is no frequency inverters.it is takeaway extractor ,
use electronic controller....so you mean I replace electronic controller to Auto Transformer Fan Speed Controllers??thx
Assuming it's wired correctly... the fan has a starting current of 9.3A and a full load current of 6A... could it be running it slowly increases the current draw beyond the 6A rating of the speed controller?
wired is correct..working normal at high speed,,,only low speed gets high temperature of speed controller... just wandering if i replace to 10 amps speed controller can sort out???
Blatant sales ploy :)
I think, as above, the best advice would be to get a sparky in to check it over. Best to be safe.
This could do with an electrician looking at it. Would be worth checking actual current draw of the fan with an ammeter when it is set at various speeds.
Is the fan connected using the 2 wire method? If so the 3 wire method is worth a trying and often greatly improves the control.
Reply to help with a fan speed controller in the UK Electrical Forum area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Local business has 3x large extract fans that simply turn on and off with individual switches. Can any brand of this type of fan be retrofitted...
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
Hey everyone. Got a head scratcher for wiring a fan with a speed control with a run on timer on site today. I, and two spark could not get it...
Hi All, Thank you for your previous advice - it resulted in us replacing our precious Smeg range with a Hotpoint; however we now have a new issue...
