- Nov 6, 2016
- 492
- 923
- 101,268
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
I get asked quite a lot about replacing old storage heaters with something more economical and I don't know what to recommend.
Some people ask for the economy 7 tarrif to be changed over to a permanent supply and to fit convector heaters.
I cannot see how this can be more economical than the storage heaters.
So basically,what do you guys recommend when you get asked this question? Do you have certain makes of heaters that you always go to? Any advise would be most appreciated.
