- Reaction score
- 2,100
be interesting to see the 'free spark' website!
Discuss Help with test and inspection. in the UK Electrical Forum area at ElectriciansForums.net
What if its over 3m from where its jointed to the 6mm?
No not retarded, just putting a case across without getting wound up or abusive for no reason?
Indeed. Get used to NOTHING being textbook (unless you become one of these guys who call themselves electricians and just pull cables in on newbuilds everyday).
I have, explained.As you have fitted a new CU you must use the appropriate protective device for the circuit otherwise your work will not comply. As above I think I would disconnect the cooker on those grounds if you feel the load is too great for the circuit..what happens after you leave is the clients business...however I think you'll find if you explain what you are doing and why they will have you back to rectify pretty sharpish..!
I have, explained.
Thanks for the revelations. Wanted to get this NICEIC quicker, I am a new business. Didn't want to use the " £250" grant I have for handing out leaflets courtesy of Princes trust.
Have two estate agent that like my idea, said they would send my leaflets to all their landlords. Wanted to send the leaflets with a NICEIC badge. Was offering something along the lines of £5 a month all inclusive callout. £40 excess. That was the idea. Also got a £1080 grant of the government and another grant of £540 there abouts. So nah I don't think I am a mug.
What you give you get back. The people I have done work for are all hard workers and good people. So .
£40 excess. The idea would be in the beginning it would be hard. But most of the time the landlord would be £5 a month, like an insurence. The landlord then knows any call out is not going to be no more £40. This is fault scenario.You must have mis-typed this.....£5 a month all in for a call out? Can you please expand and clarify your business plan and background so we can be of more help.
What we should really be asking here is the obvious question....Why, oh why didn't you just do a CU change on your own property?
Reply to Help with test and inspection. in the UK Electrical Forum area at ElectriciansForums.net
