Ok, there is 6mm to a socket then into the cooker connection unit.
I then do the checks and in the alcove seperating the toilet and the kitchen; is a 2.5 spur in trunking feeding another double socket. This double socket is for freezer and washing machine.
At first glance one would expect that it was spurred from the kitchen ring. This is not the case, it turns out this is also off of cooker circuit. There is no fuse connection unit either. The problem is he was not bothered about even upgrading his board. I asked him so that I had a weighty job for the NICEIC. Now he sees this as a head ake more than a favour; I mean imagine that caring out all this work for free and its not even considered a good thing.
I kind of been thinking though,I am gonna do a Career change. The only love I have left is finding and rectifying the faults.
Thank you for all the replies. I have left the job as it is with a 40 amp breaker, the client is fully aware of the risks. Serious though Applied for few caring jobs. ;)
JS
JS
That's like jumping from one thankless task into another.
Respect to you though. ;)
Hope nothing goes wrong with it then been left on a 40A breaker, because if you have changed the board, not followed the regs and not notified, if something does go wrong, you better learn not to drop the soap.
Don't lose heart mate ! & really lads, scaremongering about prison isnt helping! I think on reflection I would have bunged it on a 32 if its mostly in 6mm , the spurred socket in 2 five is then pretty much same as a spur off a ring, kind of almost complies in a twisted kinda way...
How does a radial 2.5 with a maximum current carrying capacity of 27A at best comply with BS7671? You got a reg for that?
sometimes a little fear will help. If he's been a total arse and unreasonable and a generally not nice I would nip back tomorrow telling him I need to put some stickers on the board. Quickly swap to a 20A MCB and wait for the phone call when it trips.
As I understand it its only the last socket in 2.5 & all I was saying was it was similar to spurring a single socket outlet from a point on a ring in a single length of 2 five, same effective protection...its there..in 'standard circuits'...
40A MCB is not acceptable, end of. You have not "left it as it is", you have "connected it to a new".
So, are you not going through with the assessment now?
Been giving this a bit of thought, i take it the kitchen is on the ground floor? Is it not worth going into a carpeted room, and making yourself a hatch to possibly crawl under/ have a good look around?
simple solution is to replace the socket outlet for a twin back box, and then put a fused spur on one half of the twin back box, feeding a single socket on the other half, assuming the client can deal with having only as single socket outlet there. If not, fit a snugly chopped out second single socket next to it to replace the lost outlet. I little bit of filler and job done.
Whole ground floor is laminated right through to toilet.
To get everyone straight, I am up for what ever It would of took. The client is not wanting me to rip up floor, out of the question. He does not like the idea of putting a 20 amp., called the term " you like creating problems don't you" he said in a joking undertone.
In his eyes his it is working. He has basic knowledge of electrics. It is highly unlikely that the cable will ever be over worked. If it did then there's the rcd. He says :/
i am thinking that maybe I could stick a fuse connection unit where the cable first appears. I can not see there being more than 3 m underneath the floor board. I am certain there will be a JB somewhere.
As for loosing heart, my head is all over the place. I really done some deep thinking today, I prob just keep to inside the circle jobs. Motivation is on a low, prob because last 5 jobs i done for free :/. Turn my website into somewhere to put all these thoughts I constantly getting :/
Thanks for all the comments.
The problem is Jimmy, you have carried out this work and left it in a possibly dangerous condition. It's not enough to just say "oh well, he doesn't want it doing." It has to be agreed with the client (even if you are doing it for free) that any issues must be sorted before re-energising a circuit. At the very least, you need to put this circuit on a 32A MCB.
