you are foreign aren't you? Where are you from?
Curious fellow, I am from my mothers belly. I am English, not just foreigners know how to pull strings if that is where you are barking.
Impossible to quote £40 max for fault finding. Sorry, but no wonder you are bankrupt with business plans like this. A bit like 'I WILL MOT your piece of she-ite car for £40, no matter what is wrong with it, I will put it right'.
I, too, am from my mother's belly, enough to know that you are not from these shores. It matters not, I was just trying to get a measure of you and your electrical/ experience/ educational background.
Jimmy, you've messed up on this one, and with the greatest respect to you (as I'm sure you're a nice guy), you sound somewhat naive. I wish you all the best in your care work![]()
Getting back to the original post (which probably isn't the main point here now) I am surprised by a lot of the responses here.
A 40 amp cooker? That is maximum theoretical demand, I would be surprised if it had a draw of more than half that for any length of time long enough to cause overload. A 32 or even a 25 would be OK, even at Christmas. 32 would allow some capacity for when the sockets are in use at the same time. The regs do not say that you need a 40 amp breaker for a 40 amp domestic cooker.
2.5mm spur off of a 6mm? Who said a 32 is not allowed? You can have a 2.5 spur of of every socket on a ring with a 32. Sounds like it is less than 3m too, so it can be fused at the far end, being the sockets. Whoever said swap them to SFCU's had a good idea. Do them both and hard wire the appliances. What is wrong with that?
To be honest, if it was an EICR you could say that the cable was effectively protected by the load, being 13a or less, fused plugs.
The only issue of note that would bother me is the inaccessible junctions, done by someone who thought it is OK to do this in the first place. If I had reason to belive it was a sub-standard joint, based on other work in the installation, I would disconnect it at the sockets as someone else said, and run a spur on the surface hidden behind the kitchen units if poss.
But then back to the real point, Jay-Snow, you really should have sussed it out first with some simple testing, especially if using it as a Nicey inspection. Know your adversary, whether it is the client, the job or you.
Cr. Ed
This 3m fusing doesn't count in domestic it's related to buss bars ... Industrial etc.
Thank you. Yes I should of, tail has been imbetween my legs the whole day. I was trying to hit too many birds with one stone.
I should of pre-tested, I took the risk knowing that I am capable of any remedy that would of popped up. I sadly did not consider the client feelings. I did push to get this job to complete what I needed. I reassured him to a point of him being convinced that the job would have little effect towards him.
I have beat myself up about it, yes I still have to rectify and I will. Let it be known though that this potentially dangerous condition would of not been known otherwise.
I am glad though like I said, I just do not have the heart for electrics. Maybe it's been the break I have had from the electrical world. I will change the 40 amp to a 32amp, this seem like the easiest position which will not effect the client.
To have messed up would of not to cared, asked questions. The £5 a month would work if one could get the clients to sign up. I am offski, thank you for the open discussion
what?...and leave em without a cooker?...dont talk stupid man.As you have fitted a new CU you must use the appropriate protective device for the circuit otherwise your work will not comply. As above I think I would disconnect the cooker on those grounds if you feel the load is too great for the circuit..what happens after you leave is the clients business...however I think you'll find if you explain what you are doing and why they will have you back to rectify pretty sharpish..!
Please tell me you wrote that for comedy value.Tell the client to get an experienced spark to do an EICR.
Electricians Forum - now twinned with Dogs Sleeping Forum ? Index page
How did you manage to find that forum ?
With a title like that,it may be worth a gander
i should cope quite well in there then....It's one to be avoided as far as I'm concerned.
It's one to go to when you feel like you want to be ripped to shreds. Quite nasty really.
You might find a socket and plug under kitchen units. Seen it a few times and customer says well its worked fine since mfi or the like fone it 15-20 years ago. Whats the cookers kw rating? Derate to 16/20amp if tests and inspects ok to do so. Label consumer unit with printed out label stating circuit no. Has 16/20A for reason, note on certificate.
If cooker is rated above 20A, isolate it at con unit by not connecting to mcb and neutral bar. Label board stating why left disconnected and note on certificate. Your backside is covered and you have left it safe.
or lastly connect to 16A if he insists on it being connected or your not getting paid and label etc..... He'll only be able to run part of it till he gets new lower rated cooker or circuit sorted.
you've left him safe, informed others via cert and labelling of con unit. Your backside is covered
Don't do this, as Glenn has already stated, you can't leave him without a cooker just because a couple of sockets are spurred off it, and probably have been forever!
Cookers are over-rated. Long live the microwave...
I had a nice dog once..............then I divorced her !
they most certainly are....
its so obvious to anyone that an intergrated grille cant be on at the same time as the cooker elements are working
further more the idea of cooker elements are to maintain tempreture...not set stuff on fire...
