G
Geordie Spark
i should cope quite well in there then....
You could end-up as admin there !!
This 3m fusing doesn't count in domestic it's related to buss bars ... Industrial etc.
It's one to be avoided as far as I'm concerned.
It's one to go to when you feel like you want to be ripped to shreds. Quite nasty really.
You might find a socket and plug under kitchen units. Seen it a few times and customer says well its worked fine since mfi or the like fone it 15-20 years ago. Whats the cookers kw rating? Derate to 16/20amp if tests and inspects ok to do so. Label consumer unit with printed out label stating circuit no. Has 16/20A for reason, note on certificate.
If cooker is rated above 20A, isolate it at con unit by not connecting to mcb and neutral bar. Label board stating why left disconnected and note on certificate. Your backside is covered and you have left it safe.
or lastly connect to 16A if he insists on it being connected or your not getting paid and label etc..... He'll only be able to run part of it till he gets new lower rated cooker or circuit sorted.
you've left him safe, informed others via cert and labelling of con unit. Your backside is covered
Don't do this, as Glenn has already stated, you can't leave him without a cooker just because a couple of sockets are spurred off it, and probably have been forever!
Cookers are over-rated. Long live the microwave...
Electricians Forum - now twinned with Dogs Sleeping Forum ? Index page
I had a nice dog once..............then I divorced her !
they most certainly are....
its so obvious to anyone that an intergrated grille cant be on at the same time as the cooker elements are working
further more the idea of cooker elements are to maintain tempreture...not set stuff on fire...
