Discuss Hi just found light without earth connected do I need to do anything with it. The case is metal. in the DIY Electrical Advice area at ElectriciansForums.net
The light fitting looks to be intended to be class II double insulated, and not earthed.
However, the way it is installed with the single earth L & N resting on the metal base, does not meet this. Plus the connector cover is missing (unless you'd just not got round to fitting it). Since you'd struggle to get the large-ish size twin & earth into that connector block with basic insulation (the brown & blue) NOT exposed, I'd be more inclined to convert to class I, use Wago connectors, and earth the metal fitting.
Reply to Hi just found light without earth connected do I need to do anything with it. The case is metal. in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
I have a spa bath, with lights, pump and lights are straight plugged into mains with 2C+E for pump, there is an additional ground wire on metal...
Hi, I do basic electrical DIY like changing light fittings and have got a light to put up that only has a fly earth and no flex earth (see pic)...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
