Discuss How can i have power flowing in a circuit where 1 item works but rest of chain does not? in the Canada area at ElectriciansForums.net
cory123
There is power flowing. I have checked with multimeter. One light on the line works..even replaced the switch it is connected to. Rest of line still down. Been down for months since a large storm although no indications of lightening strike. Replaced breaker on Sunday...no dice. On Tuesday power came back. This morning (wed) my son overloaded and tripped a completely seperate breaker that then caused the other line that had just mysteriously come back to go out once again. I replaced the breaker that had tripped as well. Still no go. I have checked the neutrals in the panel...in fact I moved the one from the bad circuit to an new open spot just to see. I am very confused. Nothing seems to be making sense. When I was replacing the breaker that tripped today on the opposite side of the box I did notice scoring or burns on the bus under the breaker above it although that breaker works fine. Might not be connected but wanted to give as much info as I could. Any thoughts from an electrician?
It sounds like you have a poor connection through the lighting circuit.
As for burn marks under the breaker are these Stab-Lok style breakers.
Stab-lok are the ones that hook on the bar and pop onto the bus plate correct? That's what mine are. I did recheck the connections behind the light fixture that does work and nothing is off. I know my basics which is why I am even more confused.
Reply to How can i have power flowing in a circuit where 1 item works but rest of chain does not? in the Canada area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I installed outdoor lighting and outlets. I finished this past year. I passed my inspection on April 2022. I was so pleased, BUT now the circuit...
