Discuss How do I record Siemens Box No. 22465A on installation Cert. in the UK Electrical Forum area at ElectriciansForums.net
I will be installing a new Ring main for a kitchen install and have come across a cut-out that is totally new to me.
Has anyone seen one of these..and how do I record its details on my Certificate.
add 1 zillion dollars for shipping frm US.
For a Ring Main he'd need at least something as big as that, and how big is this kitchen that needs a ring main fitting?
Must be huge.
Or, the part number could be wrong, and it is actually a ring final circuit that is going in?
If you are referring to the supply protective device, then for a domestic supply, it is usually, but not always, a BS1361. Could be a type IIb, but unless it is marked on the casing, then you either ring up the DNO, ask them if they know (unlikely), or put down N/A or unknown.
You will be installing a 'ring final circuit', not a 'ring main'.
Google it, and see what the difference is.
I've installed a few 630A split ring mains. They weren't in a ruddy kitchen.
Go to SpecSavers first, then go and have another look.
Ok guys thanks for correction. Serves me right for going on Plumbers forum last night.
Most likely 60A rewirable going on the size. Wouldn't be surpised if it isn't a fused neutral. Thats an old DC head.
Get the DNO involved.
Reply to How do I record Siemens Box No. 22465A on installation Cert. in the UK Electrical Forum area at ElectriciansForums.net
Not sure whether this is the right context or even forum to mention this, but I’ve recently been offering out myself to a friend to help get his...
