Discuss Immersion heater circuit in the Canada area at ElectriciansForums.net
Y
YTSOxford
Just wanting to check and get advice on immersion heaters. I have wired up them before but on the job that i'm on, the house is needing 2 3kw heaters for 2 cylinders. The consumer unit is less than 10m way from the airing cupboard, so would a radial circuit with 4mm cable and a 32mcb be okay?? Or do the heaters have to be on seperate circuits?? cheers.
Also isn't there something about a heating vessel containing --- ltrs requires it's own circuit? haven't got the good book to hand so cant check.
Shakey one for you there mate :D
Personaly I'd go down the 2 circuit route.
Reply to Immersion heater circuit in the Canada area at ElectriciansForums.net
I've purchased a horizontal unvented cylinder that has come with 2 immersion heaters. I was hoping to use the same circuit the my existing tank...
Hi, I know it's best practice to run an immersion on a dedicated circuit but am I OK with the following A new heat pump is being fitted and it...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
