Discuss Infra-red switch in Bathroom? in the Lighting Forum area at ElectriciansForums.net
Hi all,
I’m hoping someone may be able to clear up something. We do have an electrician but he is unsure of whether this can be done or not so is currently re-reading through the 18th edition.
So the scenario is this, we are currently re-doing our bathroom. It will have IP65 led down lights, 2 above shower area and 5 in main bathroom area, for this we would like to use an IP44 IR on/off switch, you do not need to touch it, just wave your hand in front around an inch away. Can this be used in place of a pull cord? The switch will be located in Zone 2. It is not in a splash-able area as there will be a fixed glass shower screen right next to it, with a sliding shower door the other side.
Whats puzzling us is we have also got an IP44 led mirror which does have an IR sensor on it and this is going to be above the sink, this will be in a splash-able area if people were to wash their faces In the sink. So theoretically if those mirrors are allowed above a sink with an IR sponsor, then surely the main light switch being an IR sensor would be fine also?
We have been waiting for nearly 3 weeks for a response from our electrician :nomouth:
Thanks in advance :blush:
you could have a senor in there in zone 2 and not have the pull cord ,but you need to put the sensor on longer the a minute or at night having a shower and the sensor turns off after a min .
It sounds like you have a specific switch in mind for this job, what does the manufacturer say about installing it in zone 2 ?
Only switches of SELV type are allowed in zone 2, but it would also need to be IPX4 minimum which you say it is.
There are no zones with specific requirements apart from suitability for the environment round a hand basin, just bath and shower areas.
How about using something like a Quintec wireless switch?
Hi,
We have one of these on the upstairs toilet which is great as people were forever forgetting to turn the light off on the outside of the door. Downside is you cant switch it off. We are looking to install some deck lighting to the underneath of a shelf to give the bathroom mood lighting if one wishes instead of traditionally using candles. So a switch is needed to turn the main lighting off.
Cannot install a switch on the outside as it leads off a hallway which will eventually become part if an open plan living space. It's a few years off that but kinda thinking ahead ☺️
I did look at these but this has to work on a 2 way switch doesn't it?
[automerge]1572891021[/automerge]
Yes, been looking into selv circuits. The manufacturer doesn't specify zones unfortunately just that its ip44 rated. It has 240v in and out of the box with a 12v cable to the IR. It's an isolated switch controller if that means anything to anyone.
The safety source of SELV has to be installed outside the zones. This is usually most easily acheived by installing it outside of the location, most often in the accessible loft space above.
Yep we have a lot space it's going into ? we are a dormer bungalow so have a space for it to go. I'll speak to our electrician again see if he is a little more assured by our plan! Thanks for replying, much appreciated.
[automerge]1572892094[/automerge]
Thanks for all replies so far, I'll speak to the electrician again and point him in this forums direction if he still needs reassurance.
Hopefully he's happy! ?
What do you class as a 2 way switch?
From your description you just want to switch on the lights using 1 switch. Is this correct?
If this is the case then you can use a Quintec wireless switch. You can use as many switches as you like but it will work with just 1 switch, if you want.
Ah, must have been another one I was looking at, but only worked as part of a 2 way system. I shall have a look at this thank you
Reply to Infra-red switch in Bathroom? in the Lighting Forum area at ElectriciansForums.net
Hi, I live in a property built in 1911. It has had asbestos artex applied to every ceiling in the house. I am currently creating a new...
Hi Everyone! You all seem like a friendly bunch and google keeps referring me back to here but I still cannot find any solid answers so...
Hi, I am not an electrician and looking for some electrical advice. We have had a new electric roller door installed at our warehouse. The door...
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
