The Dc runs can be quite long certainly longer than the <10 m Figure most people are told on the Pv courses ,the one I did the lecturer did a volt drop calc based on 230v most domestic systems will have voltages over 300v, and stated a maximum of 10m but when we had to do an example using a module sheet to calculate the array parameters etc he was proven wrong but still insisted it was bad practice with no reasons to justify it.
The length of run this is dependant on the voltage output from the panels, you can work this out manually or use sunny design for SMA inverters
the next thing you need to decide is how practical it is to run the Dc cable around the building ie how you are going to protect it from damage in accessible areas
We try to avoid putting inverters in lofts ,anything electronic will last longer in cooler conditions and most inverters derate there output when they get hot read the manufacturers instructions viewpoint (and install accordingly) it is to run
