Discuss Is brown tape on switched live a legal requirement? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all,
I've had a complete rewire in my house as part of a renovation. I've noticed two things that I wonder if they are in line with regs:
1) the electrician has not put the little bit of brown tape over the blue or black wires that are switched live. Is the brown tape just best practice or is it a legal requirement?
2) I've got metal switch plates. He connects the earth to the back of the plate, but not to the little earth block in the metal back box. I guess the screws connect the plate to the back box, but is it ok from a regs angle?
Thanks.
I think 'legal' is the wrong word but they are inclusive regulatory guidelines and thus not complying would require you to justify the excursion from the regulation especially if for any reason you found yourself in a legal wrangle as you would have to show you were in compliance with the guidelines otherwise you wouldn't hold much credibility in court.
Tape isn't great as it can come off and the requirement used to be to use something 'permanent' i.e. sleeving.
If the metal back boxes have an adjustable lug they should be earthed. Otherwise there is no requirement - as per guidance notes.
Neither 'issue' seems to be any major problem though IMHO.
Although anyone who knows what they are doing would know it's a switched a live marking it would be advisory. However the back boxes do not need earthed, as you mentioned they are earthed through the faceplate screws
Hi all,
Thanks.
No because BS 7671 isn't a legal document.
I'd be more worried if there was no green/yellow sleeving on the cpc.
Last week I was working in a neighbours house changing their white accessories to metal decorative.
A number of terminals were not tight on the cables, and cpc at switches into a choc block connector, but NOT onto the metal back box.
There was, however, brown sleeving where required
Hi all,
Thanks.
....I bet there's a queue of sparks,waiting to quote for your next job....;)
Reply to Is brown tape on switched live a legal requirement? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi, I've bought a "yagusmart" smart switch from Amazon and it has no earth terminal. Although there are no metal facing parts I would think the...
