Discuss LED Window Display Problem? in the UK Electrical Forum area at ElectriciansForums.net
Ended up getting a call and going back around late this morning! They dont like the digital timers and the lights dont work. Timers taken out and cables Wago-d (new word lol) up. Tested the circuit to make sure, told customer/s that the sockets are fine so call your window display chap. Bill going in tomorrow with extra on it for today.
I think I'd put a logging multimeter on the supply for 24 hours just to make sure nothing is affecting the supply had a similar type of problem some time ago and found there was a supply problem the local DNO had a failing joint at the end of the street and the voltage was dropping by 40 - 50v at times for anything from a few seconds to 10 - 15 minutes
UNG top recommendation Sir, I did think of the supply for a minuet until I looked down the street with 4 other shops with the same window display system. Theirs are fine, process of elimination = Not the supply. Besides a new data hub just installed and has not gone down yet (data logged for down time by the provider. Nice bloke, good to work with).
Strange how the window display chap has not called me today?
My problem is now sorted so it's up to him.
I'm not talking of a complete loss of power but a voltage drop circa 40 - 60v seen it happen quite a few times, thinking back a mate of mine who works on EPOS systems had a problem at home with electrical equipment dying for no apparent reason so he borrowed a mains analyser from work and found he was getting voltage spikes of 1100v for less than one AC cycle the DNO eventually traced the problem to a local substation
Are the 4 other shops window display systems on the same phase as yours though. With the data hub they tend to have power supplies that will work with a wide range of supply voltages so may not necessarily be affected by a voltage drop
...and anyway,if it's an estate agent,tell them it is not a "power failure",it's a "current limiting economy feature"....very sought after,these...:stooge_curly:
Reply to LED Window Display Problem? in the UK Electrical Forum area at ElectriciansForums.net
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Im trying to keep up with paper work from my hospital bed just using my mobile, but I could do with a few pointers to do with a problem landlords...
Firstly i'll point out that i'm the property owner and the installer of the majority of the electrical fittings in the building, including Main &...
Hi Guys, I am currently getting a kitchen overhaul and want to install some unit/kick-board lights. I want to be able to control the unit lights...
8K
