Discuss Metal clad CU upgrade for elecsa assessment in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
C
colface
Hi guys, I have my elecsa assessment in the next few weeks and im going change the cu at my sisters flat.
The cu is supplied by a swa cable so im going to use a metal clad cu and im finding it hard to get a daul RCD met clad cu.
Would it be ok to just use a split load met clad rcd board?
I will put the fire alarm and door bell circuit on the non-protected side and all other circuits on the rcd side?
Will the assessor be happy with this??
I know the 17th regs basically say everything should be on a rcd!! Cheers
wylex do a 5 and 5 for 90 quid all in which includes 10 MCBs, I have installed literally dozens in the last 12 months.
Terminate the SWA into a metal adaptable box and use an insulated CU
Reply to Metal clad CU upgrade for elecsa assessment in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Advice required from the more experienced and knowledgeable. Has anyone installed power to one of these prefab concrete garages with a steel roof...
Hi all, Planning on wiring my neighbour's summer house which will be 15 metres away from the end of the house (20-25 metres total distance from...
7K
As the user name states, I am not an electrician but I am trying to be an informed customer when dealing with a friendly local sparky and the...
5K
