Discuss Mini Fridge causing TV to black out ! in the Electrical Appliances Forum area at ElectriciansForums.net
I am surprised that a brief droop is enough to power off a regulated DC power supply. bakingreview.com
If extender uses an RF path to forward IR commands ,or simple signals .. It's more likely the "Signal" is scrambled by interference.
.. any extreme volt drop mentioned (was a symptom indicating possible "Design" calc. issues )
When your refrigerator compressor turns on there is a huge inrush of current for a second or so while the motor engages. Afterwards it settles to a much lower value, but during the surge the voltage on the line can droop. Do you have other things on that circuit? I am surprised that a brief droop is enough to power off a regulated DC power supply. bakingreview.com
Yes I have the same issue everytime my mini fridge starts my screen that is connected to my study vídeo receiver goes out for a split second. What part do I need to replace in the mini fridge? I don't want to spend 100 to get a new one.
Reply to Mini Fridge causing TV to black out ! in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, I have been having issues with our fridge causing my modem and video card on my pc to drop out. -They are on the same ring circuit, have...
Hi there I’m looking for some help as I have what seems to be an electrical issue. It seems to relate to my computer PC, the fridge freezer in my...
Hi there, Just about to move into a house with 2 small kids and the wiring/electrics haven't been updated in years (hard to know as it's probate)...
Good evening all. I’m a new member and found this place by searching for some info on a problem that has developed. I used to be a sparky in the...
