Discuss Monitoring Household Electricity Consumption Accurately / PV System in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
What is a good inexpensive accurate monitoring device to measure imported Household Electricity consumption, whilst using a PV system?
CT clamps don't indicate directionality of flow.
If a solar system exports energy, no current is being imported into the house, yet a CT clamp will measure the energy as though it is inward flow.
Does anyone sell a device that can measure imported current flow, whilst subtracting the effect of the generated solar power?
Ideally the solution would work with EnviR's and allow me to send data to PVoutput.org via a netsmart, via my router?
Any solar sages out there with this wisdom?
I have been speaking to the manufacturers of owl monitors today, and yes they are comming up with a solution which they say will deal with harmonics, etc on the wire to give a more precise reading compared to other electricity monitoring devices.
The OWL | Intuition -pv
Hope this helps, not available till june though
Wattson solar is pretty good, it has good software, ecoeye is bringing out new solar monitor with non contact voltage monitoring to catch out off phase night time consumption readings.
Reply to Monitoring Household Electricity Consumption Accurately / PV System in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
V.early days, just had installed solar. No battery, also supply of some parts difficult at the moment so no App or Online monitoring. I have a...
Hi, Similar'ish question to my other thread but little more info now so a different approach but sorry if duplication. UK, single phase. Just had...
Hi all. Bit of a weird one. Have solar PV with a iboost +. All was working fine until meter was exchanged for a smart meter. The system is still...
4K
