Search the forum,
Discuss Multiple audio devices to IP cameras in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
The cameras are poe
Why do you need an extra power supply?
Just plug the microphones into the jacks..
Are you aware of the legality of recording voices rather than just images?
Hi Charlie,
Unfortunately, there is no power output is available. Also, fully aware of the legality of recording audio. It is on Private property, so the client isn't recording general public
What voltage is your POE power supply? The Bosch camera needs 12V but will work up to 48V. If the supply voltage is high enough the simplest way to power microphones would be with a POE splitter/regulator, this sort of thing..
The PoE is HIKVISION DS-3E0326P-E. Due to the distance, the PoE had enhanced power outputs on the switch ports.
I have heard mixed reviews on the splitters. Would these diminish the performance of the camera device itself?
If we're to add these splitters into our CAT6a, I'm sure this will diminish the 10gbps data transfer speeds?
It looks like your PoE switch is 100Mb/s not 10Gb/s. The splitters @Shoei linked to are compliant with a 100Mb/s newtork so I'd buy one and test it out :)
The cameras only need a couple of Mb/s each at full resolution so it may well be that a slight drop in network performance makes no odds.
Thanks Jim, you have been super helpful!
It looks like the splitter doesn’t carry PoE through to the camera device (only data), so I am not sure this will work at all :(
I’ve purchased two and delivery tomorrow, so I’ll keep this thread up-to-date incase someone else experiences this issue in the future.
Thanks all
Reply to Multiple audio devices to IP cameras in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, I am in the process of setting up a diesel heater to warm our conservatory and need to provide 12v power to it. I have purchased a CCTV...
7K
I've bought a new (to me) car and the location of the cigarette lighter socket means it's better for my old dash cam to be hard wired. Handily...
4K
  • Locked
I have had a bunch of camera, I'm trying to find a camera I can leave and it alerts me when it's found somebody. I don't want DVRs and cables...
Years ago, I cut off the front end of my 1970 Pontiac Catalina before I drove it to the junkyard. I created a bracket and mounted it to my garage...
Hi All I'm thinking of installing a CCTV wifi camera at the front of my house. I would prefer for it to be wired and was wondering as I have my...
