Discuss Off grid solar and earth return in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
So despite living working in a country blessed with 300 days of sunshine I have not got my head around this solar thing, there is very few companies here who know what they are doing and buy off the shelf kits and rarely do they perform as sold and in many cases unregistered ones actually cause increased bills instead of feeding in correctly.
Anyhow I have just completed a full rewire on a villa in the back of now where and is totally off grid, they had another company fit an impressive system that we have intergrated into our rewire and it all works well but, for the life of me I cannot see how to provide a working earth return path on the consumer side.
I wired an off grid house previously with old lead acid battery system ( yes I know ) ( fitted by someone else ) and the instruction said the earth of the battery pack was the zero point for the consumer side earth return after the inverter of course, and it worked and was able to achieve good readings etc.
However this new job has a rack style lithium set up which looks great but was very expensive and cannot see how to get any kind of earth return to the consumer side, I fitted a large earth rod to achieve lightening protection for the solar panel grids, but the system itself been off grid has no relation to network ground of course, any ideas guys?
Thanks in advance
Reply to Off grid solar and earth return in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi All, Main issue is as per title: inverter is stuck in Off-Grid mode. I used Self Use over the summer, which worked well, priority PV order...
Help please, this is my first post on this subject regarding solar panel / battery installation into house with 3 phase supply. I am a DIY level...
Hi, Really just for info. not a problem or anything. (to be honest also wanting to be sure it is taking from solar as much as possible & can you...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
5K
My little house in Spain sits in the forest and has a little wire from the electricity supplier, 20 amps max. It's a fragile link, caught up in...
New Posts (Please Reply)
