- Reaction score
- 4,325
A small generator (even with AVR) supplying a UPS and then your home is not a good solution because the UPS monitors the voltage and frequency of the generator supply to decide whether to switch over to battery power; the UPS will forever be switching between generator and battery to supply your home as loads are started and stopped. Far better to use an off-grid hybrid inverter which integrates in one equipment an inverter, a large capacity battery charger (and some an input for solar panels). Use the inverter to provide you with a higher quality mains supply than available from the generator and employ the generator only to charge the battery. With this scheme one buys an hybrid inverter with a higher power rating to do both the light and heavy duty power supply; the generator can be smaller in power but runs for longer and at a constant speed to charge the battery. Explore inverter generators for the generator role which are quieter and more economical to run. Always buy a Honda engined generator and run on LPG not petrol.
Honda EU22i LPG Propane Door Mounted Dual Fuel 2 | Honda Engines and Generators | Gear GB - http://www.geargb.co.uk/product/5000-HOND2-19002/Honda_EU22i_LPG_Propane_Door_Mounted_Dual_Fuel_2.2kw_Generator
I have used these:
1. Charger and inverter:
2. Hybrid charger, inverter and solar controller:
Don't buy an inverter/charger without an information display.
I have used these:
12V solar panels charging kits for caravans, motorhomes, boats, yachts, marine
12V solar panel solar charging kits for motorhome caravan boat campervan yacht marine off-grid
www.photonicuniverse.com
