Discuss Old imperial conduit box lid screws in the UK Electrical Forum area at ElectriciansForums.net
Maybe just run them through with an M5 tap?
Well said that man as there is 2 ie 2BaA and 3/16 and as Marvo said get a M5 tap as you should have a set of taps and a dwang as they call it up here I carry 3.5mm 4.0mm 5.0mm and a bag of 5mm screws.
Just to add I do a lot of repairs so work in a lot of older houses with conduit that is also the main earth so I have seen wood screws jammed in the holes and rarely have I seen 2 screws in any conduit box hence why I tap them out to 5mm All sparkies should have various taps in their toolkit
This was also my line of thought. Usually when you go to the trouble of sourcing the correct imperial threaded screws you'll just find you're no better off because some animal has previously forced an oversized self-tapper into the hole.
Not sure what a 'dwang' is but I assume it's a tap holder. If it's on site and easily accessible I usually just use my small battery drill or I have ratchet tap-holders if it's in the workshop.
If you ever get stuck with ur usual wholesalers for strange screw sizes RS always have it and they take cash or card these days so you don't need an account.
Yep Tap holder is called a dwang up here as in Tap n Dwang lol and I have had my dwang for 38 years so as Trigger say look after your dwang..........................................
Now that brings back memories!! The old brass BA was a damned good system. Still have a complete sets of BA ring, open jaw, and box spanners somewhere!!
i still got BA taps and dies from schooldays.
Reply to Old imperial conduit box lid screws in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
I have an older Crouse Hinds board with a 200A service. Due to recent rehab on the house, I found I have the need to install a sub panel. I...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
Hi I am looking to install some driveway up lights on my new drive way, either side of my drive is grass/gravel (soft dig) I have spoke to a...
4K
