Discuss phone charger for use in a bathroom. Is there such a thing? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for everyone’s suggestions.
I’m going with a 2 port euro module similar to the mk one mentioned earlier.
Just need a nice long lightning cable so I can charge my phone and play games on it while sitting on the throne.
Just thinking. I use a fitbit, and I got into the habit of charging it every few days when I had a shower. (charging it every few days, not having a shower every few days!:rolleyes:)
Is there something i can use inside the bathroom to give me a standard 5v USB socket?
Of course you can get a single socket with a usb in it, but cant use that in the bathroom.
Could I take a supply from the shaver socket, but would it have to come from the output side of the transformer?
Could I use a regular plug in usb charger with European pins and plug it into the shaver socket?
Any thoughts?
Or bin the fitbit get trainers run till your knackered, walk back , you know like we did in the old days
Be careful using shaver sockets. They have very poor regulation and can go up to around 280v on very low load such as a phone charger. If your charger is rated 100 to 240v use the 110v socket which on low load is around 130v.
Just for the sake of the thread. The MK module mentioned has ‘don’t install in a bathroom’ in the MI despite the SELV rating.
Found while my electrician was working through my new refurb spec!
interesting, probably due to high moisture levels corroding the internals.
more a warrenty issue than a safety issue I expect.
but if the MI says no then,
it is unsuitable for that use.
Exactly that. Missed opportunity with most new small rechargeable everythings being USB now. I noticed that the new model toothbrushes are usb with a ‘British bit’ added In the box to allow for our old fashioned 2 pin use.
I have changed the spec to a shaving light with USB (Ansell).
[automerge]1574697697[/automerge]
Even this has MI that state not to place any item being charged on top! It’s IP20 re zones too.
So my solution to this issue of USB was easy and compliant. All compliant shaver sockets support UK Shaver (not same pin spacing as euro socket) and US socket (. Which is the same as standard US).
So, buy a USA mains to USB adapter, as I have, and it works just great, and is isolated by the shaver socket transformer. You do have to plug into the 110v socket. I also found that plugging into this locks out using the 240v at the same time just in case you were thinking USB and Shaver/Toothbrush !!
Ended up reading through this resurrected thread and the MK module seems perfect in most respects, even having isolation on the AC side when nothing is plugged in so no IR test issues and no wasted power.
Minor problem is the instructions say "Suitable for fixed installation in dry interior locations only" so I guess a toilet is fine, but not with bath/shower present?
Surely wearing it on the shower is better? I mean it's an ideal chance to check yourself over and as we know one thing leads to another, it'll improve your step count drastically...
Reply to phone charger for use in a bathroom. Is there such a thing? in the Electrical Tools and Products area at ElectriciansForums.net
I'm about to do wiring for a small apartment in Azerbaijan. Mostly I will try to use UK standards - ring mains with ELCBs, everywhere earthed, T&E...
Just wondering what folks think about in terms of 13A sockets with built-in USB charges, what are the good/bad/ugly of choices? I could do with...
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
Hello, I have a EV charger that is reporting over voltage and is unable to charge. the charger will operate up to 253V The solar inverter reports...
Hi, I live in a property built in 1911. It has had asbestos artex applied to every ceiling in the house. I am currently creating a new...
