Discuss Problem with extension leads in the Canada area at ElectriciansForums.net
catdog
HI
Have problem when using extension 13amp lead tp power welder or industrial angle grinder, it seems to either blow the flug fuse regularly or the socket of extension lead burns out- any suggestion of different protection or is there a heavy duty sockets availabe for extension leads?
thanks.
cable is always uncoliled so there should be no probs there, not sure what size cable is off hand but shodl be big enough to handle, it's industrial tyoe with rubber like outer and cable prob is 9 or 10 metres.
Reply to Problem with extension leads in the Canada area at ElectriciansForums.net
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
I had a fault finding job on Thursday, intermittent RCD tripping. 2 actually, there was a 30mA RCD upstream, and a 30mA RCBO protecting the...
5K
Hi guys I have been tasked with upgrading some old rewireable fuseboards for a food warehouse that runs continually 24/7. I was asked to do an...
