- Nov 6, 2018
- 1,621
- 1,253
- 102,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Hi all,
Looking at a project whereby client wishes to use some second hand (approx. 8 years old) panels, inverter etc. he has acquired from a demolished property.
Before getting subbies in to quote on re-installing them I am wondering your opinion on the output of the panels as someone has suggested (not on here) that an older panel may not be as efficient as a new one today of equivalent size? Could this be the case? If so would the cost of replacing them out weigh any benefit gained by re-using panels (especially if the addition output is minimal)!
They were also retro fitted to an existing roof and it has been suggested that they be re-installed flush with the roof tiles. Again views on this please, is it possible?
Cheers
Cheers
Cheers
Cheers
