Search the forum,
Discuss Question regarding filling in the box for verification of Main bonding Conductor. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nazoom
Hi
I am trying g to fill in the Electrical Installation Condition Report, section J. my question is regarding checking the boxes in the section Main protective Conductors. If I have a high value for main protective conductors say to incoming water. What happens to the box Connection / continuity verified for main provide bonding conductor? Do I put X on connection verified or do I put a tick in the connection verified? And then off course I ll put X on the box for incoming to water service.
The installation is TN-S, Domestic.
Many thanks.
if the bonding conductors exist and you can confirm this , then you put a tick in the verified box.
if the conductors are damaged , undersized or any other problem , then record this in the defects section , but still tick the box to say they are there.
So what happens to the box for incoming water and incoming gas. Do i tick them as well if there was a fault or do i put X?
you put x if it doesn't exist, you tick if it's there, you put N/A if t isn't applicable, if it is there then tick and if theres a problem then make a note about it in the area asking about defects etc, simples
Agreed, if the connection is there then you tick the box. You may want to make an observation if the reading doesnt make to magical 0.05 ohms once you have considered all the factors that could effect the reading (e.g. length of cable run. x-sectional area etc ... )
Reply to Question regarding filling in the box for verification of Main bonding Conductor. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
This is a question (or discussion probably) regarding selecting the main earthing conductor, and subsequently the main equipotential bonding...
7K
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
