J
james1985
hey,
I am currently completing City & Guilds level 2 and stumbled across the below questions and scratching my head...
1. Electric Fire element has a length of 10m, a cross section area of 0.5mm2 and resistance of 50 ohms - calculate resistivity of material used.
R = U x L (SorryI don't know how to use the correct symbol for resistivity)
......... A
Resistance is equal to resistivity x length divided by the area
Any material has a natural resistance.over longer distances the resistance gets higher
If the area is increased,the resistance gets lower,distance and area are proportional
From the information given and the values you can transpose the formulae to work out the resistivity
Upvote 0
Des, from using that formula - I could not locate the material used. Not matched the resistance level provided...
Upvote 0
hey,
Have you not been taught how to calculate the resistivity of a material, it's quite a simple formula
Upvote 0
......... A
Rho
Reactions: Des 56
Upvote 0
This is taking me back decades
If I were given the information I would look up what material most heating elements are made from (mostly nichrome) then find out its value of resistivity and go from there
Upvote 0
Rho to you from me as well Pete :)
Upvote 0
I only gave an example of a material if it was not known
Again I say you have the information to work out the problem
Upvote 0
Not going to tell you the answer James, google how to calculate the resistivity of a material? the answer is there.
Upvote 0
No Rho= LxA/resistance, watch out for the csa part, you will need to find the sq root of 0.5
Upvote 0
Upvote 0
  • Funny
Reactions: Pete999
Upvote 0
Ok so am incorrect in saying the answer is 2.5?
Think so yes, just thinking I used to be good at this sort of thing, age certainly take it's toll on the memory. Hang on til Dave gets back don't want to add to the confusion.
Upvote 0
p = (R x L)/ A
Upvote 0
Its fairly difficult to write the formula and/or a worked example so here is one. Hope it helps. It is simple but you need a sci. calculator.
Upvote 0
Upvote 0
Resistance Level 2 - HELP NEEDED!!
Electrician Courses : Electrical Quals
james1985,
james1985,
Electrical Courses
