P
pablod
hi,
when i installed the cables for a ring in my own house i clippped the cables in the channeled wall leaving a cable width between (no correction factors). if you run the cable in pvc conduit which seems about 100 times quicker surely correction factors for grouping need to be used (0.8). do you sparkes work the figures out. and is it the same on the switchs for lighting circuits.
thanks
paul
thanks
paul
