Discuss Screw through the lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
B
Blademan_98
I did something silly today :(
I bought a new luminaire for the kitchen and decided to put it up as a surprise for the wife.
The fitting was in a different orientation to the old one so after going through the safe isolation procedure, I removed the old fitting and screwed up the new one 90 degrees around.
Wired everything up and stood back to admire my handiwork :)
Flicked the MCB on and, you guessed it, flash bang MCB trips.......
I had screwed through the cable in the ceiling cavity :mad2:
So a 20 minute job became 2 hours whilst I made good the damage.
I am really annoyed with myself. I don't expect you pro's ever do anything like that!!!!!
Cheers
B
As @plugsandsparks says, stuff happens. I had a really annoying experience a few years ago fitting a shower screen. As I hadn't owned the house for long, I wasn't aware of the plumbing and electrical paths, so I was ultra-careful before drilling anywhere, and (usually) checked with a decent (Bosch) wall/stud detector.
Well in this case I had checked, and everything was OK, until, about six months later, I came home to a large puddle in the dining room- near the aquarium. Naturally I thought it had sprung a leak, but on closer inspection it was clear it hadn't lost any water. Turns out the tip of the screw on the shower screen had pierced a plastic pipe (undetected by the Bosch), but had self-sealed at the time. Only months later the tip of the screw rusted and let the wet stuff out.
A friendly local plumber advised me on a 'fix'- a small s/s woodscrew, a touch of silicone & a jubilee clip round the whole lot to be sure. AND A shorter screw for the shower screen!
Trev I have had to edit your post to remove a word, you know the one I appreciate you altered it but swearing isn't allowed mate.
Best example I heard was when I was at school. Alarm fitter putting in new burgular alarm, checked for cables with his live wire detector, then started cliping cable into place, POP and the lights went out. The school was wired in MI and thus screened the cables.....
Cheers
B
Correct :rofl:
Sounds like a plumber 'fix' that yes. Daz
Reply to Screw through the lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
  • Locked
5K
Hi all Can anyone please advise, i have fitted a new fused light switch cover in the kitchen as the press switch part broke on the old one...
