Discuss Simple Tamper Alarm box lashup in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Derekb
Hi
Im attempting to quickly knock up a temporary alarm using an external alarm box (no control box) with a tamper loop wire wrapped around some kit
I will be using a external sounder, long length of multicore cable and a 12v power supply.
the box is a XS3D
terminals.....
ST- strobe
TMPR tamper 0v
S- bell -
12V supply
0V supply (bell hold)
im guessing link tmpr through loop cable back to 0v and connect 12v +/- to supply.
Does any one have some experience to give any guidance
Dez
take 12V to 12V + and 0V supply, 1 leg being the tamper loop. when the tamper loop is broken, the sounder will activate off it's own internal battery. you won't get strobe, though.
Does that means im using the negative leg of the supply to act as tamper ? (wire loop)
What about the boxes tamper connections do these need to be connected somehow ?
Dez
Wiring as Tel suggested, use box tampers as normal, back plate and cover, again if remove will set of siren only.....
I have it up and running and looks good
I used the tamper for (-) neg loop to supply, (+12) pos supply and left the 0v disconnected, this allows the internal tamper switch to activate the bell box when cover removed.
Does this sound about right?
I have a 12v 1.5mA DC supply driving it but the bell sounds a little quiet, any comment on that ?
Dez
Reply to Simple Tamper Alarm box lashup in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all Is it possible to connect a Texecom Odyssey 1E sounder to an Optima panel using 4 core cable and still allow the bell, strobe and tamper...
Hi . Im running some conduit , a long horizontal with metal clad boxes , with vertical runs to a term box for light fittings and a couple of smoke...
So, for a bit of completely pointless fun really, does this antique looking item that was acquired entirely for novelty/aesthetics value work...
I’m in two minds whether to change my current 18v Dewalt SDS/Combi/Impact. I currently work in the Fire and Security industry. Mainly doing Alarms...
Hi, first time poster here, been on the plumbers forum for years but have a question about an alarm box that I need a pro to help with :) Got home...
15K
