Discuss Small IP rated cable connection... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
Octopus
Need some ideas please chaps. Ground workers have damaged a 12V cable running to a light - so I need to put a joint in to it. Its 12v DC so only 2 cores to worry about.
So far I've considered:
Wiska Shark - the 6A version
and
The TubeTee IP68 inline connector
Are there any others I could use? Space is tight!
TubeT seems the cost effective measure, couple of through crimps and jobs done, got one of those in a machine been drenched by cooling fluid, its still going strong yrs later, the wiskas are just as good but you pay more for the same result.
Or just solder and heatshrink each joint and adhesive-lined heatshrink over the lot. I do so many hundreds of these for various reasons, if space were limited I would not think to do it any other way. I stagger the joints (in groups if there are a lot of cores) and infill the space between the ends of the sheaths with PVC tape to maintain a uniform external diameter so that there's no tendency to kink in the middle when flexed.
I've taken to using solder sleeves more and more in recent times. Very quick and easy especially if you're in the middle of nowhere, you just need a small butane pencil torch/soldering iron. They also come with hot-melt glue at both ends so they're water tight and it also provides some nominal strain relief. You can also use heat shrink sleeve over them afterwards.
Here's an example but I'm sure you'll find them much cheaper. | RS Pro Solder Sleeve Low-Density Polyethylene Blue, cable diameter 2.3mm → 4.5mm, 29.3mm sleeve length | - http://uk.rs-online.com/web/p/solder-sleeves/8726286/
Reply to Small IP rated cable connection... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
