Discuss socket outlet in the UK Electrical Forum area at ElectriciansForums.net
A
ample current
A microwave oven is to be installed above a built in oven in a tall kitchen unit, is it ok to have the socket behind the microwave inside the unit? or is it better to make a hole in the back of the unit and have the socket outlet on the wall.
If I remember right the part of the unit which houses the oven wont have a back and be open to gain access to the wall. don't really want to put the socket there though.
Thanks for your thoughts
I'd be checking the depth of the cupboard before doing anything.
Most Microwaves and kitchen designs haven't thought or allowed for the cable & socket!
Most kitchen I have seen have had the socket behind the microwave as the depth is only 450mm. There is enough space in the back for the socket and plug. As for wether its a good idea or not is down to the installation itself
Reply to socket outlet in the UK Electrical Forum area at ElectriciansForums.net
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi, client wants some sockets and 20a switches moved into high cupboards in kitchen and above 1200mm for tvs etc, the apartment was built in 2016...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
