Discuss Temporary power pole question in the UK Electrical Forum area at ElectriciansForums.net
I am trying to set up a temp power pole for new construction home. I have everything pretty much laid out, but started questioning the connection from the meter to the load center. I have a 125 amp meter socket and a 70 amp square d main lug load center with 20amp breaker to power gfci receptacle. My 70 amp panel will only accept #3 wire. With 1/0 wire feeding into meter, can I use #3 coming out into the load center? Thank you for taking time to help.
As far as a temporary power pole all you are required is # 6 wire and since your panel is main lug only then you don’t have anyway to cut the power off to the main panel. The only way you can use the panel is to buy a 60 amp double pole breaker with a tie down kit to make it legal. Probably your best bet is to get a panel with a main breaker and don’t forget your ground rod.
Reply to Temporary power pole question in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Hello --- In the planning stages for a new custom home build -- The house will be several hundred feet from the road and I want to have the power...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
I have 2 kitchen lights, each on its own switch. I would like to re-wire them to where the first switch turns on both lights, but where if the...
