O
Octopus
So its now less than 1 year to metal CU's and fire retardent cable entries.....
So is this a good idea or not?
I think its a ill thought out requirement and needs to be reconsidered...
So please vote in my poll!
I think it's bloody ridiculous Clive. I cannot for the life of me understand why the requirement is being put on us and not the manufacturers.
Plus metal CUs usually look crap.
Reactions: 5 people
the only thing that needs reviewing is the poor standard of installation. if fitted correctly there's less chance of a fire than a geordie buying a round.LOL.
Reactions: 5 people
You want to visit Norfolk mate , they have all got short arms and deep pockets here ,
If the new regs state that metal DBs have to be fitted in domestic installations I will continue to fit 960 degree glow wire tested plastic DBs in domestic installations as it is a very easily justifiable departure. The reason for the five fold increase in 'fusebox' fires isn't down to the material they're made out of its down to the thousands of under trained and under skilled idiots fitting sub-standard products to a sub standard.
Edit: see here for an explanation on how it is an easily justifiable departure from BS 7671:
http://www.electriciansforums.co.uk/electrical-forum-general-electrical-forum/98557-holy-grail-bs7671-amendment-3-plastic.html#post1052649
Reactions: 11 people
Absof&&kinlootly correct mate couldn't agree more,
Reactions: 1 person
I don't think metals CU's are the answer. Improving the installation standards and the quality of the products would make a much bigger difference in my opinion. Dual screws for main connections would be the minimum I'd expect.
Reactions: 7 people
I don't think this has been thought through enough - it seems to me a few incorrectly installed consumer units have caught fire so the IET have tried to legislate against incompetence by bringing in this reg, with little apparent consideration for the benefits of a correctly installed plastic CU over a correctly installed metal one, such as electrical insulation and resistance to corrosion.
If they're going to insist on metal CUs just in case they're installed incorrectly (to offer increased protection from fire but decreased protection from electric shock in the place you need it most, ie before the protective device) you have to ask "what's next?" Will we see all plastic accessories 'banned' just in case they're installed incorrectly and could start a fire?
Reactions: 1 person
So a CU catches fire because cables haven't been tightened up in a mainly plastic MCB or main switch. To counteract this the bods at the IET bring in a reg to state that they should now be made of metal, but they still contain lots of plastic which will still (potentially) not be nipped up properly thus the arcing and heating can still occur and cause fires.
Sorry but I'm not seeing the logic so as Damian says above I think I'll continue to install plastic ones because my risk assessment says the same as his.
Reactions: 4 people
I still fail to see how they're going to get around metal DBs in domestic TT setups?! Of course an up front s-type should be fitted anyway but this will now need to be within a seperate enclosure before the metal DB, and the enclosure material housing the s-type, will have to be? You guessed it... PLASTIC!
WTF?!?
Reactions: 1 person
Bit of a double edged problem here.
witness the decline in manufacturing standards( mk 80/90s vs today's tat being a prime case study)
coupled with poorly trained installers
result is far more charred lumps of plastic than before
saying that I went to one on Wednesday night that was an old Wylex m/c feeding storage heaters with the main switch burnt to a crisp and the tails joined together in an unholy live neutral Union of melted plastic insulation.nice.thankfully quite rare as well.
as I've said before as an apprentice you never got near the board part of the job as it was a pile of bits that had to be built up with a bit of knowledge.
that was the journeymans bit of the job
once he deemed you competent you might get a wee 4 way to do as a test to see if you were up to it
and woe betide if it was untidy!
now you buy a fully populated board and if you don't know what you are doing it leads to disaster
stop selling populated boards to the untrained and it might be a start rather than making you do all metal.
ill get my torque driver.........
Reactions: 3 people
Remember the Reg does not state that the dis board must be metal, but that either it or a cupboard housing it must be non-combustible.
Don't forget your cable penetrations into a steel enclosure, I wonder how many people actually carry edging grommet?
I second the general consensus, if installed correctly, where lies the issue?
Can't use grommet strip, that would mean that the fireproof seal of the metal casing would have been broken. The only way around this issue is to use fire proof glands. Either that or normal glands and then a heap of fire foam squirted over the cable entries.
Gonna look well nice in the customer's hallway innit! :D
Reactions: 3 people
......but they still contain lots of plastic which will still (potentially) not be nipped up properly thus the arcing and heating can still occur and cause fires.
I'm sure that I read somewhere they've developed a steel hybrid compound made from 80% mild steel and 20% bull5h1t which has great insulating properties and they're going to start making the MCB's and the busbar insulators from it.
I don't understand the requirement in the new amendment, there's no tablet for stupidity and ineptitude, why start accommodating these qualities in the regs.
You could radically reduce the CU fires with a thermal image so wouldn't it be much easier to include thermal imaging with a basic flir camera into the EICR or whatever that test certificate is that you do on installations in the UK.
New regulations like this are made a mockery of by the lack of the necessity for retrofit upgrades. If the old standards are now deemed dangerous for future installation, then surely by that logic, they need to be brought up to the new standard?
It's the same with alterations and EICRs. How can one part of an installation (to previous regulations) be OK to leave in service, but an addition must meet a new (higher?) standard?
It's double standards, is what it is!
Time to voice OUR opinion
Octopus,
Maddison,
